RCU Forums - View Single Post - Jetcat Kero problem!
Old 03-23-2009 | 10:25 AM
Guillermo Ibanez's Avatar
Guillermo Ibanez
Default RE: Jetcat Kero problem!
ORIGINAL: olnico
ORIGINAL: Gonzalo38
I normally use Duralite 4300 mah batteries and if this is not enough, I can always use 5200 mah Fromeco's.
Once again the capacity of the battery has nothing to do with its capability of providing high currents at a stable voltage. You'll need batteries with an impedance of 10 mOhm or less.
Hi
Anybody knows the impedance fo the Hydrimax Ultra 4200 mAH NiMH 6.0 volts (5 cells) battery?
