RCU Forums - View Single Post - Engine Fires...
Old 03-23-2009 | 01:16 PM
siclick33
Default RE: Engine Fires...
As causeitflies says, startup fires generally aren't a big deal unless they cause damage to the airframe. They tend to be short lived.
It helps if you start your model pointing into wind and it is imperative that, if you have to use your fire extinguisher, you point it in the engine intake and not up the exhaust.
