RE: Engine Fires...
Personally I would be very careful with that technique. As long as you are on the ball it is fine but if you are a bit slow and open the tap a bit late you risk an overtemp.
As Pete says, the ECU shouldn't pump fuel if the gas doesn't raise the temp beyond a pre-set limit. If the gas doesn't light, the fuel shouldn't flow.
