If the short wasn't instantaneous (but arcing for a couple of seconds) then the noise generated might have interfered with the receiver.
Older firmware versions of Spektrum receivers will go through nearly 2 seconds of reset recovery time under these conditions. If this was a Spektrum receiver, sending it in for a firmware upgrade will do the trick. Recovery from such an event is nearly instantaneous.
