RE: Switch failure Issues with Flight Pack
Don, if you are using a servo hatch, you can glue a piece of string to the hatch and tie the other of the string to the battery charge lead. To check your battery or charge the plane, you can remove the servo hatch which has the correct lead attached.
Also, if your wing is properly potted to the fuse, you should not be getting trim changes after removing the wing.
