RCU Forums - View Single Post - Please help setting up floats on a cub
Old 03-23-2009 | 08:24 PM
JimCasey's Avatar
JimCasey
Default RE: Please help setting up floats on a cub
If you set the top of the floats parallel with the flat part of the bottom of the wing, you should be OK. That will give you a couple of degrees of actual incidence.
The photo gallery at Brown's Seaplane base gives you a lot of cool scale details for Cubs on Floats.
