RE: Tx ???
I am not aware of any receiver that is as you describe. The only way that I can see doing what you are asking is to remove the receiver from one plane and install it in another. The other option that is possible is to get a transmitter that has model memory built into it. Then you have 3 planes all with a receiver installed and only one transmitter that allows you to change planes. As for the brand, that depends on what you have or are wanting to get. If you have for instance a Futaba transmitter that has 6 model memory, you would need Futaba receivers, up to six if you used all the model memory on the transmitter. Good Luck, Dave
