RCU Forums - View Single Post - Running engine in reverse Harmfull?
Old 06-14-2003 | 02:42 AM
DBCherry
Default Running engine in reverse Harmfull?
While most glow engines can start backwards, applying throttle will usually cause them to quit. I doubt that it ran backwards for long. It's fairly common practice to flip larger four strokes and gas engines backwards against compression when starting. It usually causes them to bump into a forward spin then start.
Aside from that, if it did run backwards I don't think it would cause serious harm.
Dennis-
