RCU Forums - View Single Post - First Kit 4*40
Old 03-24-2009 | 12:04 PM
mclina's Avatar
mclina
Default RE: First Kit 4*40
You can usually get the plans copied at Kinko's or Staples for about $10 a sheet. One bit of advice that comes up here is that you should be sure to check the accuracy of the scale on the copy before you pay for it. Copiers can tend to be a bit off, and the operator should be able to adjust it until it is close to perfect.
Good luck
