RCU Forums - View Single Post - RCGF Engines
Thread: RCGF Engines
Old 03-24-2009 | 11:44 PM
  #2525
stangevil29
Default RE: RCGF Engines
To all,
I have chosen to put the 26cc in the seagull 120 spacewalker but, before I buy everything I noticed that I would probably have to cut a pretty good hole in the firewall in order to mount the engine in accordance with the manual. ( Prop hub to firewall dimension). Is this not a good idea or will this be no big deal? Will I have to worry about getting fuel all over in the plane? It should only be a little over an inch behind the firewall. I dont know if this would cause problems letting air get to the carb. and if I have to cut a biger hole will it be detramental to the firewalls integrity. Thanks in advance.
Stangevil29
