RE: Nitroplanes Seawind
Hi.. Alo
Good luck in the building process hope to see some nice photos... I think with a 60 size engine would be Ok but a bigger size engine will help a lot especially in taking off the plane need some additional nose weight in order to balance this of....
Mine is nearly ready all I need to finish this is install the receiver and set up the transmitter..... I have still the water rudder to fix as this is not working properly and it’s loading the servo.... I will see into this and will let you know how she balanced off.... I am using a TT 91FS.
Also can you check if you wing servos are located on top or bottom mine are on top I emailed the factory as I own a hobby store and get these directly from them and said that this is on purpose in order to reduce water spray
Let us know how things are going..
Michael
