RE: Using Hitech servos with Futaba 2.4 Ghz receiver.
Ok, so you mean to say that only the 6014 receiver has the 2.7Volts signal voltage and the 617 would still be using the 3.0Volts and hence Hitecs would work without a problem ?
I read the other thread referenced here, but it was not clear if the hitec servos would work without a problem.
altavillan , are you using a 6.0 volts battery with the 617 Rx ? and no problems ? I just want to be double sure before i invest into the hitech servos for my 50 CC yak.
-Gaurav
