RE: Trouble with Quark SRB
Simple fix.
A gear on your tail drive shaft is slipping. Remove your tail housing and pull out your shaft. Proceed to super glue the gear on so that it holds. Then put everything back together and you should be flying. This takes about ten minuets.
