RCU Forums - View Single Post - vx 18 troubles
Old 03-25-2009 | 08:37 PM
  #32
perhamrocks's Avatar
perhamrocks
Default RE: vx 18 troubles
ORIGINAL: Brett185
The Tx and the Rx have absolutely nothing to do with the carb. At least if you have your throttle trim turned all the way down like you should, then it won't, no, wait, it still won't have anything to do with the carb even if you have your throttle trim up. You guys do know that you don't want your servos to control your idle, it should be up to the carb alone to handle that. You need to have your throttle trim all the way to zero, then set your idle screw to where ever you want it.
i have been told from many wiser people on these forms that it does matter that the transmitter and reciever must be on for you to see the idle gap in the carb to move
Edit: [link=http://www.rcuniverse.com/forum/m_5359250/tm.htm]idle support thread[/link]
check out the 4th post by HimotoracingUSA who is the head guy of support and distributing ofHimoto products in the US
