Originally posted by captinjohn
Is this correct about the 2 -1200 ma nicads connected in series? 2X 1.2 = 2.4 volts. Seems kida high for a 1.5 volt glowplug??? Can you really hook two glow plugs up in series. Can someone draw this out
Thanks Capt,n
Its simple. Connect the plus to one glow plug and the minus to the other plug( in series with the switch). The engine connects the two plugs together.
Just make sure to use the same make and type of glow plugs in both locations.
