RCU Forums - View Single Post - soldering
Thread: soldering
Old 03-26-2009 | 09:14 AM
brett65's Avatar
brett65
My Feedback: (18)
Default RE: soldering
ORIGINAL: Rodney
The biggest problem with extensions is that, after a time, if the connector is in a place not frequently mated/demated, corrosion slowly builds up and causes intermittent operation. It is always more reliable in those cases to solder in an extension.
If that is a real concern for you, then use some dielectric grease like is used on spark plugs.
