RCU Forums - View Single Post - BRAKE SYSTEM BLEED DOWN
Old 03-26-2009 | 09:45 AM
lov2flyrc's Avatar
lov2flyrc
My Feedback: (24)
Default RE: BRAKE SYSTEM BLEED DOWN
ORIGINAL: [email protected]
I haqve the Ultra Precision -6 Brake valve.
Pat
Leak is most likely before the valve or you servo is not releasing the plunger completely, I highly doubt the UP6 is leaking.... Pinch off the feed line at the valve with hemostats and see if the pressure still bleeds off, simple way to be sure if the leak is at the valve or before.
