RCU Forums - View Single Post - Trouble with Quark SRB
Old 03-26-2009 | 10:41 AM
EastcoastJJ
Default RE: Trouble with Quark SRB
ORIGINAL: fiddlesticks1
Simple fix.
A gear on your tail drive shaft is slipping. Remove your tail housing and pull out your shaft. Proceed to super glue the gear on so that it holds. Then put everything back together and you should be flying. This takes about ten minuets.
That was it, thanks
