RCU Forums - View Single Post - Malfunctioning EDF
Old 03-26-2009 | 11:39 PM
jimmyjames213's Avatar
jimmyjames213
Default RE: Malfunctioning EDF
ORIGINAL: chad32u
Great info. My brain is growing with each thread. Is there a way I can get the tx/rx to work again (if that turns out to be the issue) or will I have to get warranty service? Thanks again guys.
is it 2.4? if so bind the reciever to the transmitter again? (i dont own 2.4 so im not much of a help)
charge your tx battery?, are you on the right model?, transmitting in the right mode (ppm /pcm)?
other than that, i solve one problem at a time. make sure it is a rx/tx problem.
their are so many variables. isolate the problem before you try to fix it.
