RCU Forums - View Single Post - Which Covering ?
Old 03-27-2009 | 07:19 AM
wattmeter's Avatar
wattmeter
Default RE: Which Covering ?
ORIGINAL: goirish
I think that depends on if you are going to use a lot of trim. Like a starburst for example. If so then use Monokote because you can use the windex method of applying the trim (will not work with Ultracote). If you are not planning on using much trim then go with the Ultracote as it is easier to stretch around curves and shrinks better. Just my 2c
So does that mean if I use Ultracote I will not be able to use any trim on it?[]
