RCU Forums - View Single Post - Which Covering ?
Old 03-27-2009 | 07:51 AM
jetmech05
Default RE: Which Covering ?
there is no reason you can't use the windex method when appling Monokote over Ultracoat....after all you can iron Monokote on Ultracoat...all the windex does as goirish said is start to activate the glue.....I like Monokote better...as you can use a higher temp, without worring that the covering will shrink too much..
Good flyin
