ORIGINAL: bonebreak
You could add some small washers behind the engine mount on the right side to push the engine to the left. This is a cheap and easy fix.
Correct, BUT it should be pointing to the left only if you are looking at it from the front. If you were sitting in the cockpit, it should point to the right
