RE: Which Servo do I use>?
I am not aware of a written guide as to what servo to use for what application. Most manufactures list on the kit or ARF servo suggestions. If the plane is designed for 3 D or is getting into the bigger size planes, you will need to get bigger and better servo's. If your war birds are over the normal 60 size plane, I would upgrade all my flying surface servos. Good Luck, Dave
