RE: BME is a joke.
Carb bolts are aluminum, Reed block bolts are steel. I fear the reed cage crushed or will get wiped out when the motor is turned over. There's only about 3/64" clearance when done right. Taking off 3/16 from the reed block kinda guarantees the next post will be evan more IRATE[>:]
