RE: perry pump for OS 120 AX - does it help
McChiken,
Sorry I missed your post from 2 months ago, I don't frequent this forum much.
I always run my fuel pickup line to the rear of the tank just like normal.
I would check your pickup line for a split right where the brass tube ends inside the tank, you could have damaged it when you removed the front end off the plane. This would cause the motor to go lean when the tank level reaches the split.
