RE: RCGF Engines
The weather is starting to turn for the better. I was able to take the plane out and start the rcgf 62 engine with 22x10 prop. Ran the engine at 2500 rpm's for 10 min, let the engine cool and then repeated it. After 20 mins I ran to full throtle with a fish scale. It only showed 21 lbs. Not sure if I need to make some adjustments or just go fly. The engine sounded very good. Slight hesitation on run up, but othere than that, it started very easy. Ideas???? or just go fly???
