RE: Echo BME twin
I went to parts tree and saw the parts and numbers.I will order me a set also.I might just try the the 33cc ones i have anyway and then compare them to the 61 later.But the 61 should be a lot better in performance.
And like you said,much lower profile.Im also going to weld my crank first to check all the heat settings then do yours.I already pmed you to let ya know what was going on.
The hub is already done.If av8tor purchases the reed setup let me know and ill ship it to him for ya or ill just send it back to you.Im going to send ya another pm as to not hijack the thread with a bunch of personall things about your case,crank,ect...
