Posted February 11, 2009 12:44 AM
DURATRAX Shock Rear Assembled Evader EXT
This is a pair of replacement Assembled Rear Shocks for the
Duratrax Evader EXT - DTXC8972*.
FEATURES: Plastic construction, grey in color
Factory assembled and ready to install (oil is filled)
Replaces worn or damaged rear shocks
INCLUDES: Two Factory Assembled Rear Shocks
SPECS: Length: 4.5" (114mm)
http://www.hobbysuperstore.com/browse.cfm/4,94897.html
*the link takes you to the front shocks... you want the rear shocks using the mfr. code above!!! They come as seen above, in a package of a pair for left and right. You'll be needing 2 pair, so you'll need to order 2 packages. This is where my hobby shop screwed me, so make sure you get 2 pacakges and not 1!!!
