Basman
The wings are done, servos installed and hooked up. Got the engine mounted. Replaced ARF tank with an 11oz Hayes. Odd arrangement of bukheads - the ARF tank would have sloped down in back - not preferred. Also, would have had to cut out to fit. Does yours slope down?
The instructions are unusual. For a while, they are complete and thorough with photos. Then they start skipping important items. Wouldn't recommend as a first time build - too many things a beginner wouldn't know.
Couple of questions on yours: Did you mount the battery under the nose box as indicated? Did that cause any balancing problems? I noticed you have a fuel fill valve; what is it mounted on and does this make for a long engine fuel line?
Steve
