RE: Seagull Ultimate 46 Wing Incidence
The batt sits inside a large pice of foam stuffed in behind the tank. ( I brought it built ) The filler valuve is mounted in the cowl , and could make for a long fuel line sometimes it takes a bit to get the fuel up. Bal no problem 11cm top wing as stated in manual ( down loaded from net ) Check that measurement going by memory.
Whens the maden ?????
