RE: BME is a joke.
Thanks RCU, I still don't have permission to edit my posts. When do you folks figure you've punished me enough?
Referencing my previous post, it's notable that even with some of the more current eastern imports you may not receive the support you should have. An example is my recent attempts to order parts for an engine in need of repairs due to a crash. They were difficult ot locate and once received did not fit the engine due to design changes made by the factory in the short period of time since the engine was released. That fails to note the deplorable quality of some of the new parts. Cylinder head fins are not supposed to have numerous hols in them other than where the head screws pass throguh the fins. Nor should the pistons slam into the cylinder crowns with correctly dimensioned heads. I can see adding one gasket but not two or three to obtain a usable squish band. Support is not just having someone "in business", it also requires that you can obtain what you need and what you are provided is functional.
