CG Super Chipmunk sheeting issue.
I am ready to put on the leading edge sheeting on the first wing panel. My problem is, the sheeting that is the correct width is too short. The sheeting that is long enough is too narrow. Do you glue the wider pieces together in order to get it long enough? Am I missing something? This is my first build.[&:] The instructions are a bit vague in this area. Also, What are you using for power for this plane? I am considering either OS 75ax or a Magnum 91 four stroke. I do love my Saito 100 on my 4*60. Thanks for any advice.
