RE: CG Super Chipmunk sheeting issue.
use the ones that are long enough to cover right or left side. Joint them in the middle of the wing. Then use however many you need to cover the wing from leading edge to trailing edge.
I am planning to build this one soon. Just ordered it from Tower. I plan to do a few mods specificly fully sheet it and then glass it for paint. The purpose is to practice glassing and to have one to practice landing for my upcoming warbird builds. (higher wing load) I will be taking wood out where I can to compensate for the added wood for the glassing.
Question:
Has anyone put two servos in for the alerons instead of the bellcranks? If so how did it workout?
If anyone put in the flaps how did they workout?
Sharpeye
