Problem with brand new Futaba 9CAP
Did you charge it fully before you tried to set everything? I would call futaba or send it in. Sounds like the display is bad, or was screwed up when you turned it on. Could have been caused by a lot of different things. You need to fully charge a new radio before turning it on from what I have been told by everyone else in the field. Warrenty should take care of it if it came out of the box that way.
