RCU Forums - View Single Post - Some Pre-Flight Questions..
Old 03-30-2009 | 07:23 PM
causeitflies's Avatar
causeitflies
Default RE: Some Pre-Flight Questions..
If you've read the old threads on the SM F16 you'll see that the CG range varies widely from 145mm to 175mm. Some guys swear that 145 is way nose heavy and some say it's perfect. I just split the difference and left it there. I think 145mm is a good starting point and the plane should fly fine but may need some up trim.
