throttle servo problem
check the wires.
make sure they arent pinched,frayed, or anything like that. check the connect to the servo and swap the throttle/steering servo and see if the problem follows to the swap. if so it might be the rx.
did you run through a lot of puddles? water hurts ofcourse.
check the linkage to make sure its functioning properly.
