RCU Forums - View Single Post - Class Survey (please help)
Old 03-31-2009 | 11:02 AM
J.D.T
Default RE: Class Survey (please help)
go large scale, a fan mounted to a car alternator will make 13.5 volts and 60-155 amps, you will need a voltage regulator to keep from boiling the battery dry unless you match the in and out current pretty well, I would try a single big motor but wheel motors are always an option
