RE: question about engine running...
To use the tachometer to tune your engine, you put the tach on the prop while leaning out the needle until it peaks. Read that peak rpm off of the tach. Then re-tune the needle until the rpm is about 500 rpm below that peak value. Then you are good to go flying.
