ORIGINAL: matador_24
ORIGINAL: Allfat
To use the tachometer to tune your engine, you put the tach on the prop while leaning out the needle until it peaks. Read that peak rpm off of the tach. Then re-tune the needle until the rpm is about 500 rpm below that peak value. Then you are good to go flying.
Hello, sorry, some clarifications:
1. what do u mean by "peak"
2. what is "line out", close the main needle or open it some clicks???? Before this term, I just knew "lean in" (close the needle) and "rich out" (open the needle)...
Thanks!
Matador,
"Lean Out" and "Lean In" mean the same thing, like "Flammable" and "Inflammable". Just delete the "out" or "in", and lean the mixture by screwing in the high speed needle.
Actually, with some engines, I can richen the air-fuel mixture untill RPM starts to drop off. Then I lean the mixture until I
just get back to peak RPM, and call it good.
Best wishes,
Dave Olson
