RCU Forums - View Single Post - RCV 91CD full throttle problem
Old 04-01-2009 | 02:11 AM
pauser98
Default RE: RCV 91CD full throttle problem
In my case, at peak rpm, there is still about 2mm to go before the barrel is fully opened.
Now I set the engine servo to travel to this limit, otherwise during take-off and if I fully opened the throttle, the engine spluttered and the take-off is aborted just before lift-off.
I did disconnected the whole carb assembly and blow directly through the inlet opening while slowing opening the throttle. I noticed that the air flow increased progressively as throttle is opened, and just beyond the 2mm-to-fully-open mark, there is a "whoosh" and air rushed freely through. Maybe this causes the splutter as the air mixture becomes too lean?
I will remove the crowl and do a pinch test again as Bill suggested.
Chris
