Antenna wire routing
hello all,
I currently have the antenna wires routed out of the fuselage and pinned to the vert. stab. on all my aircraft. I'm not a big fan of this arrangement however... Would there be any problems with signal if I were to run the wire through a pushrod tube or just route it back through the inside of the fuselage? What if I ran it all the way back and just had the last bit of the wire coming out under the tail?
