Problems
You never said if you had each servo plugged in a receiver channel or are you using a "Y" If you are using a "Y" you will have to adjust the linkage and the servo spline/gears so that it all lines up. If you have it plugged into different channels, you can change the end points of each half so that they move in sync.
