RE: How to improve 3D flying?
The key to a stable hover (and stop the plane from gaining altitiude) is definitely learn to "pump" the throttle. Each burst of air rushing over your tail feathers actually helps to keep the hover stable. The hard part is to learn to pump the throttle AND use your rudder at the same time. Takes some getting used to, but as you move on to more complex 3d, the throttle pumping becomes even more of a necessity.
