RCU Forums - View Single Post - Falcon 40 lift problem...
Old 04-02-2009 | 05:33 AM
nascarfaad's Avatar
nascarfaad
Default RE: Falcon 40 lift problem...
pb1592,
The Falcon 40 forum is found here. http://www.rcuniverse.com/forum/m_4826535/key_/tm.htm Are you still using the OEM motor? The stock motor doesn't last long, so most flyers are replacing them with the Slo-Max 300 or Century motor. Also look for binding between your main gear and motor pinion. Hope this helps.
