RCU Forums - View Single Post - Antenna wire routing
Old 04-02-2009 | 09:17 AM
beau0090_99's Avatar
beau0090_99
Default RE: Antenna wire routing
I could see a problem with the antenna in the wing when it comes to flying the 'standard' pattern. You are generally flying around in a circle and often the wing tip is pointing directly at you and theoretically you get a loss of signal, like if you were to point your Tx anntenna directly at the model.
Does anyone concur?
Curtis
