RCU Forums - View Single Post - Antenna wire routing
Old 04-02-2009 | 09:50 AM
perreback
Default RE: Antenna wire routing
I see your point. If you do fly around in a circle and, on top of that, constantly aim your antenna at the aircraft as you follow it around, then you might not get the best signal, but it will still be good enough not to matter. However, I'm not sure that people 'generally' fly around in circles.
