I have some straight methanol that I used on mine. Denatured alcohol also works good, just make shure the stuff you use DOES NOT contain water which can rust the daylights out of your stuff.... just bad [8D]. I cleaned out some engines that came from some cars from a neighbor that were ALL gunked up with old fuel using denatured alcohol and they cleaned out real good (same couldn't be said for the engines
