RE: Redcat vehicle repair/tune FAQ
Forgive me I didn't see the quote button at first.
TuffGuy31: My volcano seems to be stuck in neutral??? I start it and the engine just revs when I pull the trigger??? It revs but goes nowhere??? what could it be?????
I am having the same problem. Mine started right after I hit a little bump ... I did about a six inch jump and when I landed, I started having that problem. My spur gear is fine, so I opened up the tranny, everything looks fine in there, it's almost as if the bearings on my two drive gears are too loose (which I doubt very seriously is the problem, just trying to get the point across). They rotate just fine,but if there is any pressure on the drive shaft, it won't spin, the gears just rotate around it. I have been searching for hours for someone else with the same problem. I will definitely pass along a solution if I find one.
-Desmond
