RCU Forums - View Single Post - Your best building blunders! ...post em' here.
Old 04-03-2009 | 09:17 AM
Don Brent
Default Your best building blunders! ...post em' here.
Since I just made one, I thought it'd be fun to read about some others...
I'm finishing up my trainer and one of the last steps was to connect the fuel lines to the engine. Now this was an ARF build that had a 3yr interuption due to unpleasant life events and so it was quite a long time ago that I installed the fuel tank. The last part of the fuel tank installation was to attach one end of a single piece of fuel tubing to the fuel supply outlet and the other to the vent line and pull the loop through a slot in the firewall. Additionally, this plane has a cowell which I had to modify due to a rear mounted remote mixture needle and is very much a pain to remove and re-attach.
So anyway, I'm so excited about finally finishing the plane that I just connected the fuel lines without really stopping to think... and then it occured to me that I have ABSOLUTELY NO IDEA which line was which... If it's wrong, then I've already cut the vent line too short to reach the nipple on the muffler and will probably have to remove the cowell and engine and re-tube the fuel tank... Or I could go by another fuel filter and use it to splice another 2" of tube to the vent line... (might be a good idea to have a filter on both lines anyway).
I'm liking option two...
Don
