exi le
nitro staff... i need a main shaft for the exe le (limited edition) you show that you have them in stock under the part number 31147, but this is not the correct shaft or part no. the correct part no.(i believe) is 32147, can you please check this out and get the proper shaft for the exi le ( the shaft for the LE is longer)
